Hi all,
I am trying to build a computer and I am getting the error code D6 when turning it on for the first time.
Here is the build:
  • ROG Strix Z690-E Gaming WiFi
  • Intel i5-13600K
  • Trident Z5 RGB DDR5 (2x16GB)
  • Gigabyte Gaming OC 12GB 4070Ti
  • Seasonic Prime TX-1000
  • WD_Black SN850X 1TB NVMe SSD
  • Noctua NH-D15
  • NZXT H5 Flow
When I try posting the machine after building it, the graphics card lights up and the fans begin to spin, then maybe 5 seconds later the fans stop spinning and the lights turn off. The motherboard then finally lands on error code D6. (Note: the only things plugged in are: the power cable, DisplayPort cable, usb keyboard, usb wireless mouse dongle)
Things I have tried so far:
  • Unplugging the GPU and using the iGPU as well as unplugging and reseating the GPU. Result: error D6
  • Using the Seasonic included 12VHPWR as well as the Nvidia branded 12VHPWR to pcie psu cables. Result: error D6
  • Reseating the RAM as well as using only one stick of RAM. Result: error D6
  • Reflashing the bios using BIOS Flaskback as well as clearing the CMOS using the Clear CMOS button. Result: error D6
I don’t have a separate motherboard that works to test the GPU, but because I get the same error message when I try to use the integrated graphics on the cpu, I suspect it is not the graphics card fault but instead the motherboard. Is there any other troubleshooting measures I can try to take before RMAing the motherboard?
Thank you in advance
EDIT: The issue has been resolved but I do not know exactly what fixed it so Ill just say what happened in case someone has a similar problem.
After trying different things to no avail, I tried turning off the hybrid mode (no fan) on the power supply and suddenly the iGPU started working. I went through the Windows 11 install process and updated the nvidia drivers (Windows was detecting the gpu but when I tried to switch to it, it did not work). Then I tried moving the HDMI cable plugged into the motherboard down to the GPU (I had primarily been using DisplayPort on the GPU) and it worked. I then tried unplugging the DisplayPort cable and plugging it back in and it finally worked. Im not sure where along the way the GPU started working but hopefully this helps
https://linustechtips.com/topic/1505587-rog-motherboard-error-code-d6-issue/
