Budget (including currency): 1000-1500
Country: USA
Games, programs or workloads that it will be used for: R6-Siege,csgo, some AAA singleplayers
Other details the only part I want to keep from my old build is my 3080. My current build is an i9-9900k and 3080, ddr4 32gig 3200mhz.
https://pcpartpicker.com/list/Czss9r
This is what I have currently picked out.
Edit: I play 1440p as well
Edited by TenjaFPS
https://linustechtips.com/topic/1504864-upgrading-my-current-build/
Country: USA
Umm your current build is already good enough?? Anyway ya the new stuffs seem pretty good just maybe try going for the k version not kf
Those should be fine for 1440p, whats the main issue you have, Siege in particular assuming thats your main title.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Country: USA
Solid build ^^  This psu gives you PCIE5.
https://pcpartpicker.com/product/nhC48d/msi-mpg-a850g-pcie5-850-w-80-gold-certified-fully-modular-atx-power-supply-mpg-a850g-pcie5
