Help needed. Tried everything. No display.
Solved by robspunk27,
Thinking about buying a 2nd hand motherboard. So MSI have failed me... If anyone recommend one under $100 would be appreciated. If Its not the issue then ill probably have to go a new CPU.
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals3 -
6
michaelb198 ·
Posted in Peripherals2
