Budget (including currency): 2000$ USD
Country: United States
Games, programs or workloads that it will be used for: Resident Evil 2 and New Call of Duty games/Shooters . Mostly be gaming and on discord
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): No need for extra parts just want some feedback on the pc I've put together thx ❤️ https://pcpartpicker.com/list/JtTRrD
Edited by Braydoge
Sorry forgot to add the list
https://linustechtips.com/topic/1500217-final-build-thoughts/
My thoughts: ewww, Intel. Why a DDR4 mobo vs a DDR5 system?
However, everything is in the details. One can have the most amazing parts, but just stuff all the components in that case. Zero cable management and whatnot. Pictures could probably tell more then just the bare specs. That's something that's probably more important TO ME. And considering all your fancy components, the looks are probably also important to you.
https://linustechtips.com/topic/1500217-final-build-thoughts/#findComment-15888433
