Geetings good people of LTT!
(English is not my native, please understand i can make miatakes)
So, today my PC decided its going to have its funny day, and this is what happened.
In the morning, i turned on the pc, did some things and played a bit of aimlab, apex and it all worked perfectly.
After that i had planned to leave the hause for some time so i shut down the PC, after around 3 hours i came back home and the PC wont start.
So what i did was i started testing why, removed gpu, removed all fans, removed ram, mobo battery etc.
After that with ram inside the PC started, ok cool....BUT, as soon as i connect the power cable of the rtx 4070Ti the pc wont start, two click sounds from psu and thats it, all stops. So, i went and investigate more into it. When the gpu is inside and its not power cable connected it turns on, all lights are lit, looks fine, but as soon as one of the two 8 pin connectors touch the psu cable it shuts down. But only one of them, if the other one is plugged to the psu it work, but i cant get signal, seems it does not have enough power for the greedy 4070Ti.
Im extremely sad and would like to know what might the problem be? Is It the psu or is it the cable that then the psu prevents the power so something wont get fryed?
Can the 12 pin gpu cable be faulty in this way?
I thank you for any kind of info.
Regards!
Adam
https://linustechtips.com/topic/1498788-really-weird-pc-behaviour-help/
It sounds like either you have a bad psu cable that somehow got worse during the day or your psu can't handle transients well at all. How many watts is your psu and did you buy it new or used? Also just check if all your power connectors (excluding your gpus) are installed correctly (the power connectors click when you push them in) and do this when the computer is off.
It sounds like you have a faulty psu, normally when there are *click* sounds from a power supply. At least it sounds like you didn't break anything else in your computer
Edited by filpo
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
