Aio Noise
Solved by Hinjima,
16 minutes ago, DoubtingCastle said:When I turned it on this mourning I heard some liquid moving in the pump but I heard that this is just air bubbles and when I put the pump on extreme it seemed to have fix the problem
Yeah, most likely just air bubbles that has to move around a little. Hearing some liquid moving is also normal because, well... There is liquid inside the AIO
when I had an AIO, I always heard liquid moving everytime I started my PC! Its like when you have a bucket of water and you take a stick and move it round and round, you will hear a lot of water noise until the water gets up to speed and moves at the speed your stick ( pump ) is moving. All normal.
