PWM gives you finer control and is recommended if your fans support it (i.e. have 4 pins as supposed to 3).
DC is a bit more vague, but still perfectly fine unless you want to tune your fan speed to perfection for some reason.
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
https://linustechtips.com/topic/1496444-fan-configuration/#findComment-15860814
If your fan cable has 4 pin holes then that means they support PWM which I always recommend over DC. PWM allows a great customization where you can set the fan curve yourself (slower speeds and slow ramp up for sound, faster speeds and fast fan ramp up for thermals, etc).
https://linustechtips.com/topic/1496444-fan-configuration/#findComment-15864875
