AIO Installation Help!
Go to solution Solved by Hinjima,
7 minutes ago, Tharoon said:
Hey, I have a Gamerstorm Captain 360EX AIO cooler and I was wondering if the cable that goes from the cooler, that is to be plugged into the AIO_PUMP header, does it matter which direction it goes?
I am using the Rog Strix B350-F motherboard.
Can anyone help me?
Yes it does.  it should have a groove that should match the tab on the motherboard just like this picture here
Can anyone help me?
https://linustechtips.com/topic/1495674-aio-installation-help/#findComment-15853415
