Hello all,
I believe my current display has a line of pixels at the bottom which are dying, mouse ghosting at the bottom, not consistent as it comes and goes but there’s definitely something wrong as I have a big red line across the bottom when the monitor says “no signal” after I shut down my computer. Despite not having had it for a year, I need a monitor so that I could possibly RMA my current one.
I currently use the VG279Q1A by ASUS as a part of their TUF gaming range. It’s a 165hz, 1920 x 1080 resolution, 1 ms response time, 27” monitor and I have had a few issues with it with some things being too pixelated which I’ve been told is down to me using a HD resolution on a 27” monitor. Would like an upgrade if I’m unable to successfully RMA my current one but would like my budget to stick to that range so if there’s any better options for a similar price would be great. Many thanks all.
https://linustechtips.com/topic/1492490-need-display-suggestions/
  • 2 weeks later...
On 3/7/2023 at 1:12 AM, Admansrs said:
Hello all,
If your budget goes up to 300 and you want to use g sync too then look at this one from asus tuf image.thumb.png.7a294c3df5953ef103e9a05dcacead3a.png
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
