8 minutes ago, DorkoTheDamaja said:
I have a h510 nzxt case and a h610-A-D4 motherboard
I looked on the boards led thing and very fast flashing means dram apparently, but I had this same problem with the 13400f I bought but sent back because my board can’t update
If your board can't update, seems like it is the problem here.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
What memory kit?
No I don’t have the 13400f that need the update I have a 12600k which is supposed to work with a stock board, I’m thinking it could be the psu but I don’t know
You indicated that the flashing means an issue with memory. Why don't you start there rather than looking everywhere else for a problem?
@DorkoTheDamaja
DRAM light flashing is your first clue it's a memory issue. I agree with @brob- Start there. Check the board manufacturer's compatibility list for that board and processor combination for your specific RAM part #. If it's not listed, there could be stability issues, and even if it is, the DIMMs themselves could be defective.The board could also be defective. Your "can't update" remark is confusing.
Edited by An0maly_76
Revised, more info
