RX 6700 XT For Ryzen 5 7600X System
It's a great fit for a 7600x based system. And it's a good GPU for the price at this time (beaten by a 6750XT for roughly the same price).
As an upgrade from an RX 590, it's a great option. Let's say that - what you have on 1080p with the 590 you'd have on 1440p with the 6700XT and add some more on top.
Most current and older games would be playable on 1440p high without raytracing. For example, it can do 1440p 144Hz 142lock in PUBG with competitive settings (mix of low and high).
4K, on the other hand, is 4x 1080p (literally) and that requires a stronger card for modern games to run on 60+. If that's your goal you should look at an RX 6900, 7900...
Or wait till the middle of June when the RX 7700 and 7800 cards supposedly come out.
