So im getting this piping
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_853&products_id=22503
With this coolant
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_301&products_id=24777
Is it kind of redundant having UV blue coolant if my piping is blue aswell?
https://linustechtips.com/topic/148646-cooling-for-my-build/
With this coolant
just get distilled water as you wont be able to see that coolant through the tubes anyway, and distilled water + kill coil wont clog up your loop.
https://linustechtips.com/topic/148646-cooling-for-my-build/#findComment-1985544
With this coolant
Why not get the clear tubing then?
Good premixed coolant wont block up your system, using crappy tubing will.
https://linustechtips.com/topic/148646-cooling-for-my-build/#findComment-1985966
