Hi,
I decided to build a pc in fractal ridge, which was not the greatest idea, came with some complications.
I also probably underestimated power of the cpu and installed NH-L9x65 and lately my cpu is thermal throttling. Installed the thermaltake bend correction frame which helped to some degree but the cpu still runs hot, I am also planning to experiment with undervolting a bit but did not have time to do so.
I did some research and found out about a cooler, which should be suitable for my use, it is Id-cooling IS-55.
However only place i can get it in our country is from aliexpress from this seller:
 https://www.aliexpress.com/item/1005004856977442.html?gps-id=pcStoreJustForYou&scm=1007.23125.137358.0&scm_id=1007.23125.137358.0&scm-url=1007.23125.137358.0&pvid=15a8cd09-b6cb-408e-816c-734f6dccd01c&_t=gps-id:pcStoreJustForYou,scm-url:1007.23125.137358.0,pvid:15a8cd09-b6cb-408e-816c-734f6dccd01c,tpp_buckets:668%232846%238107%231934&pdp_ext_f={"sku_id"%3A"12000030770286019"%2C"sceneId"%3A"13125"}&pdp_npi=2%40dis!CZK!1326.73!1021.03!!!!!%402101d1c316756276996734224e00bd!12000030770286019!rec&spm=a2g0o.store_pc_home.smartJustForYou_681350971.1
I am not sure about this way, never purchased something from here, do you think it is legit?
My concern is if this cooler fits with my current MB and RAM (will all be listed below) and if not if i can modify it to fit.
Also if anyone has some other alternatives/solutions I am happy to hear them!
Thanks for any input, I am not that experienced and building/gaming is only my freetime hobby when I get a bit myself time.
Specs:
Fractal Ridge
Gigabyte Z690I Aorus Ultra DDR5
Intel Core I5-13600KF
NH-L9x65
Kingston Fury Beast DDR5
https://linustechtips.com/topic/1486353-13600kf-overheating/
the cooler itself seems to be a low profile gimmick cooler, like any other prebuilt it should thermal throttle, that fan doesn't look like it would provide the cooling the cpu needs form just the picture. 120x15mm fans are not a good fit for a cooler.
PERIPHERY
- Table : IKEA Karbly 8FT counter top (brown) w/ 2 ALEX black drawers & OLOV LEG
- Chair : Herman Miller Aeron Remastered Ergonomic Chair
- Mouse 1 : Logitech Superlight X 2 (Black) (Using Now)
- Mouse 2 : Razer Viper V2 Pro (Black)
- Keyboard 1 : Logitech G413 SE Brown switches Lubed
- Keyboard 2 : Ducky One 2 SF Black CherryMX Silver Switches
- Monitor 1 : Benq Zowie XL2566K 360HZ 0.5MS
- Monitor 2 : ASUS PG279QE 1440p 165HZ
- Mousepad 1 : The Glorious 3XL Extended Mousepad (Black)
- Mousepad 2 : Benq G-Sr Speed Mousepad (Black)
- Mouse-Bungee : Razer Bungee V2 (only when wired)
- Headset : Beyerdynamic DT990 PRO 250 OHM grey/black
- Microphone : Shure MV7 XLR
- Mixer : TC-Helicon GOXLR
- Camera : Nikon 250D W/ Elgato CAMLINK 4K
- WebCam 1 : Logitech Brio 4K
- Webcam 2 : Logitech C922 1080p
- Controller : PS5 Controller Whiteout Edition
PC
- CPU : Intel I7 12700KF
- CPU-Cooler : NZXT Kraken X62
- GPU : Zotac Gaming GeForce RTX 3070 Ti Trinity OC 8G
- Motherboard : MSI MAG Z690 WIFI
- RAM : Corsair Vengeance Pro RGB 64GB
- Case : NZXT H700I Black/Red matte
- HDD : 2x 6TB (12TB) Seagate Exos 7E10 12GB/s
- SSD : 1TB Crucial P1 NVME M.2
- PSU : Corsair RM1000X (1000W Plus Gold) (W/ Red Sleeved Premium Corsair Cable kit)
https://linustechtips.com/topic/1486353-13600kf-overheating/#findComment-15786658
14 minutes ago, Nxrb said:
Hi,
Specs:
Fractal Ridge
NH-L9x65
Can't you get a NH-L12 ? The bigger fan should help
https://linustechtips.com/topic/1486353-13600kf-overheating/#findComment-15786679
30 minutes ago, Nxrb said:
I can, however this one outperforms it.
It looks bigger indeed
Maybe a BeQuiet Dark Rock TF2 will be better and easier to obtain
https://pcpartpicker.com/product/GTpzK8/be-quiet-dark-rock-tf-2-cpu-cooler-bk031
https://linustechtips.com/topic/1486353-13600kf-overheating/#findComment-15786750
  • 4 weeks later...
I was running into overheating issues with my 13600kf aswell, Stock clocks and everything disabled in bios was still thermal throttling on a 360mm aio.
I just received a Thermalright CPU contact frame and it lowered my temperatures a fair bit, I was getting around 80c or so on stock clocks. I'm now able to hit 5.5 all P cores and 4.3 all E cores and still not thermal throttle.
     Phanteks Enthoo Primo Intel Core i7 3930k | Asus Rampage iv Formula | Seagate 4TB
Dual 480mm Coolgate + 240mm Coolgate | 16GB G.Skill Trident X F3-2400 OCZ ZX 1250W
      4GB Asus GTX 670 OC 3 Way Sli Western Digital 2TB | Samsung 830 128GB Raid 0
https://linustechtips.com/topic/1486353-13600kf-overheating/#findComment-15828895
