I need some one more educated than me to help me decide between the PNY GeForce RTX 3060 Dual 12GB XLR8 Gaming VERTO or ASUS GeForce Dual RTX 3060 12G V2 GPU.
Before judgement is laid upon me - I understand that fundamentally, they are the same card with the same Nvidia backing, HOWEVER - this is a question for the following:
  • Stability
  • Software
  • Compatibility
  • Trust
I have heard of ASUS as I am upgrading from an ASUS Dual Radeon RX580 8GB, but I have never heard of PNY before. I do not want recommendations to go and buy the latest and greatest, as I am restricted by case size, motherboard, budget and availability. I am a gamer, student and part time graphic designer/content maker. This is not for mining or anything extravagant. Please understand this, as I am not wanting trolls.
Thanks in advance
PNY GeForce RTX 3060 Dual 12GB XLR8 Gaming Verto GPU: https://www.umart.com.au/product/pny-geforce-rtx-3060-dual-12gb-xlr8-gaming-verto-graphics-card-65979
ASUS GeForce Dual RTX 3060 12GB V2 GPU: https://www.umart.com.au/product/asus-geforce-dual-rtx-3060-12g-v2-graphics-card-68097
Quote
“There will always be those who mean to do us harm. To stop them, we risk awakening the same evil within ourselves. Our first instinct is to seek revenge when those we love are taken from us. But that’s not who we are.”  - My Dad
My Specifications:
(GPU in process of Upgrade)
Component
Selection
CPU
AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor
CPU Cooler
Cooler Master A71C 38.99 CFM CPU Cooler
Motherboard
Asus TUF GAMING B550M-PLUS WIFI II Micro ATX AM4 Motherboard
Memory
G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Storage
Gigabyte GP-GSTFS31240GNTD 240 GB 2.5" Solid State Drive
GPU
ASUS RX580 8GB
Case
Thermaltake Versa H17 MicroATX Mini Tower Case
Power Supply
Corsair RM750 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System
Microsoft Windows 10 Home OEM - DVD 64-bit
https://linustechtips.com/topic/1485039-help-me-choose/
What is the rest of your system?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1485039-help-me-choose/#findComment-15777092
Pny are fine. So are brands like inno3d and gainward. They wouldn't be nvidia partners if there was something wrong with them. There are plenty of systems i've built using those cards and never had an issue with them. I'm rocking an inno3d 3060 ti atm fyi.
https://linustechtips.com/topic/1485039-help-me-choose/#findComment-15777099
@191x7 as requested:
  • ASUS Prime B450m-A
  • Asus Ryzen 9 5900x to be installed (current Ryzen 3 3400G)
  • 32gb G.Skill Ripjaws 3200mhz RAM
  • Several HDDs/SSDs/M.2
    • Seagate Barracuda 7200rpm 2TB
    • Seagate Barracuda 7200rpm 1TB
    • Seagate Barracuda SSD 480GB
    • Kingston A400 M.2 480GB (Main Drive)
    • Gigabyte SSD 240GB
    • Total Usable Storage (3918.44 GB)
  • Windows 10 64-bit
  • (Current GPU) Radeon RX580 Dual 8GB
Quote
My Specifications:
Component
Selection
CPU
CPU Cooler
Motherboard
Memory
Storage
GPU
ASUS RX580 8GB
Case
Power Supply
Operating System
https://linustechtips.com/topic/1485039-help-me-choose/#findComment-15777733
PLEASE DON'T.
That board can't handle a 5900X, the VRM-s will blow. The 5900X is the most power hungry and most heating AM4 CPU.
You are going to have issues and then probably a bang followed by some white smoke.
And the board going out might take the CPU, RAM and maybe even the storage with it.
Consult this:
That board can barely handle a 65W CPU. The 5900X is a 105W base.
I've seen that board having memory compatibility issues, issues with a Ryzen 2700, issues with a 3500X, VRM protection (shutdown) kicking in under 3DMark with a 2700X (far less power hungry than a 5900X!)...
The highest I would recommend for that motherboard is a Ryzen 5 5600 (non G, non X), eventually a Ryzen 5700X.
Both are great upgrades over the 3400G.
Also, you forgot to name your power supply. That is importan.
And is there a reason you're choosing nVidia when you can get a noticeably stronger AMD Radeon in the same price range?
For example a Radeon RX 6650XT.
https://linustechtips.com/topic/1485039-help-me-choose/#findComment-15777743
Unless it has no protection of any sort, it wouldnt blow... it will just slow down the CPU so you dont get all its performance
Desktop benching:
https://linustechtips.com/topic/1485039-help-me-choose/#findComment-15778197
@Jurruniohere's hoping it comes to that instead then.
@191x7I certainly hope not. The current PSU is being replaced with a RM750e at the same time the CPU is/was going to be placed. Is there a board that you can recommend then that will handle it?
Quote
My Specifications:
Component
Selection
CPU
CPU Cooler
Motherboard
Memory
Storage
GPU
ASUS RX580 8GB
Case
Power Supply
Operating System
https://linustechtips.com/topic/1485039-help-me-choose/#findComment-15778712
Any B550 board with a VRM heatsink or any X570 board or any X470 with a heatsink or B450 MSI boards (MSI X570 have the weakest VRM-s but their B450/X470 boards have the best out of the 400 series chipset boards; Gigabyte is usually fine, Asus too, ...).
I linked the AM4 motherboard tier list. Just find the boards you can afford and then check how they rank on the list, higher ranked = better choice.
https://linustechtips.com/topic/1485039-help-me-choose/#findComment-15778737
Thanks @191x7 I will check it out
Quote
My Specifications:
Component
Selection
CPU
CPU Cooler
Motherboard
Memory
Storage
GPU
ASUS RX580 8GB
Case
Power Supply
Operating System
https://linustechtips.com/topic/1485039-help-me-choose/#findComment-15778957
