Budget (including currency): around 800-900 euro's
Country: Netherlands
Games, programs or workloads that it will be used for: Gaming and School.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Looking to upgrade from a old PC. i already have a 3070 RTX from ASUS and a 750watt gold+ power supply and looking to bring these over to the new build.
https://linustechtips.com/topic/1483623-first-build-advice/
What kind of games are you playing? AAA?
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766690
What's your current rig? Anything recent (especially AM4)?
Trans Rights!
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766716
What website are you using to buy your parts? I'm not terribly familiar with the Netherlands/Benelux, only the DACH region.
~200€ Mainboard (for example the AsRock B650, Buildzoid wasn't terribly unpleased)
~250€ Ryzen 5 7600X
~100€ DDR5 6000MT/s (16GB)
~100€ 2TB M.2 SSD
~30€ Tower cooler
That's 680€, but the scaling in F1 2022 drops off sharply after the 7600X, so I don't see a point in spending more on a better CPU. You could double the RAM and add more storage if you need it, maybe upgrade the motherboard or CPU cooler if you want to OC.
Edited by Bismut
Sauce
Trans Rights!
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766732
~250€ Ryzen 5 7600X
~100€ 2TB M.2 SSD
~30€ Tower cooler
I use Azerty mostly https://azerty.nl/
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766801
Just now, JapanseTCR said:
Azerty
What's the website? Azerty.com is unusable for me and everything else is pointing to keyboards.
2 minutes ago, JapanseTCR said:
no it's a like i7-2600k and B75-P45 something asus modo and 870 evo ssd etc
Oh. The SSD should be good tho, given that it's got 500GB+ of space
Trans Rights!
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766806
12 minutes ago, JapanseTCR said:
its dutch so its .nl
That did the trick, but navigating that website is... difficult.
https://azerty.nl/product/msi-pro-b650-p-wifi-moederbord/5011720
https://azerty.nl/product/kingston-fury-beast-black-geheugen/4689277
https://azerty.nl/product/amd-ryzen-5-7600-processor-3-8-ghz-5-1-ghz/5064357
https://azerty.nl/product/be-quiet-pure-rock-2-koeler-voor-processor/4192976
https://azerty.nl/product/crucial-p3-ssd/4767013
There's probably better components (especially RAM) but I didn't want to wait for the website to reload every time I changed a search setting.
I also love your word for RAM, geheugen is NOT what I expected.
Edited by Bismut
Dutch
Trans Rights!
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766828
I know. sad they don't a english version but that has probally something to do with the country there going to
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766836
I can understand most Dutch no problem, it mostly looks like a funky mix of German and English to me. Spoken Dutch is an enigma though
Trans Rights!
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766852
true that also. i just live near there shop so its easy to fix problems with anything
https://linustechtips.com/topic/1483623-first-build-advice/#findComment-15766866
