Budget (including currency): 800$US
Country: USA
Games, programs or workloads that it will be used for: Minecraft (plus server), Halo Infinite, Battlefield 5, possibly streaming.
Part List:https://pcpartpicker.com/list/yQw7bK Upgrading from hp laptop w/ core i5, intel UHD integrated Graphics and 8GB RAM. buying in early February. wish to be playing in at least 720p with a Decent refresh rate.
Looking to see if anyone can find any incompatibilities or size constraints with current parts. and games that i may be able to run that i don't expect, also how future proof it is since I don't care to play games with low settings! 😄 also would want to know if I'm missing anything.
https://linustechtips.com/topic/1482635-help-with-future-gaming-pc-build/
12100F is the only sub $100 that is worth it, use it with stock cooler to save money.
Super budget B660 board, 2x8GB 3200, because 2x16GB in a budget build is really a waste of money.
1TB NVME SSD instead of 500GB, 500GB fills up really quick.
6650 XT instead of RTX 3050, RTX 3050 is a horrible value product, do not ever recommend that GPU to anyone. For reference, 6650 XT is 55% faster than 3050 for cheaper or the same price.
The case is expensive for what it is, if you like it, who am I to judge.
Same quality low end PSU for cheaper and higher capacity.
https://pcpartpicker.com/list/YXbvxs
CPU: Intel Core i3-12100F 3.3 GHz Quad-Core Processor  ($106.99 @ Walmart)
Motherboard: Gigabyte B660M DS3H DDR4 Micro ATX LGA1700 Motherboard  ($109.99 @ Amazon)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($39.97 @ Amazon)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($52.99 @ B&H)
Video Card: MSI MECH 2X OC Radeon RX 6650 XT 8 GB Video Card  ($259.99 @ Newegg)
Case: Antec NX260 ATX Mid Tower Case  ($91.48 @ Amazon)
Power Supply: Thermaltake Toughpower GX2 600 W 80+ Gold Certified ATX Power Supply  ($54.99 @ Amazon)
Total: $716.40
Occassionaly visits the forum when I have nothing to do at work.
Honestly, I have no idea about minecraft, I don't play it therefore I have no idea about the hardware required for a modded server.
But I do know server hosting is somewhat tasking, admittedly I didn't read the plus server part of your post.
So, I upgraded the CPU to a 6core CPU that is way faster than R5 5500, a bit faster than R5 5600.
About the RAM, maybe you need more RAM, I'm not sure about the whole server thing.
Also, to be clear, this build could run 1080p games at high fps.
https://pcpartpicker.com/list/y6Bmcb
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($166.96 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($64.97 @ Amazon)
Total: $801.37
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($139.79 @ B&H)
Motherboard: Asus Prime B450M-A II Micro ATX AM4 Motherboard  ($79.99 @ Newegg)
Video Card: XFX Speedster SWFT 309 Radeon RX 6700 10 GB Video Card  ($329.99 @ Amazon)
Case: Deepcool MATREXX 40 3FS MicroATX Mid Tower Case  ($52.98 @ Newegg)
Power Supply: Asus TUF Gaming 650B 650 W 80+ Bronze Certified ATX Power Supply  ($79.98 @ Amazon)
Total: $800.69
Generated by PCPartPicker 2023-01-19 23:56 EST-0500
