Building First PC - Please Advise
Go to solution Solved by Dr. Will0hlep,
First, I suggest using PCPartPicker.com as it will do alot of the compatability checking for you.
Second, 650W to 750W is fine, 80+ ratings are kinda pointless cause the tests are flawed, Instead I'd just choose a cheap mid tier PSU from the tier list on the PSU section of the forum.
Third, When buying motherboards the best practice is to buy the cheapest thing that has all the features you need. Any AM4 motherboard should be fine... however, older chipsets might require bios updates to support the 5800X.
Hello,
So I'm building my first PC  very soon. I've watched tech videos for years and have swapped out many parts in past PC's that I've owned.
I'm a little nervous for things I won't know that can be an issue until I run into them.
This is the current plan:
5800x
3070
32GB RAM
1TB NVME
ATX Case(Not fully decided which yet)
My unsure areas are with the power supply and motherboard.
From what I looked up a 650w-750w supply is needed.
My biggest question is what motherboard will fit this build best? Pretty much all I know is that it will be on the AM4 platform. I'm not looking into doing overclocking or anything like that. Also, is there any compatibility issues I need to look for between power supply's and motherboard's?
Hope this all comes across clear, thanks!
https://linustechtips.com/topic/1482530-building-first-pc-please-advise/
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
An AMD motherboard with enough VRM to handle the CPU.  Whether you want pcie4 or not depends on how many slots you use.  The 5800x implies you DO want pcie4 (because why not just get a 5500 then)  so B550 or x570 atx or possibly microATX.  If you go miniITX there’s little reason not to get a 5500 and an a320 board, as pcie3x16 will have enough bandwidth for that card.  It’s only 6 cores of course.  A 5700 would also work.  NVME wise if you go pcie4 980pros are popular as they’re pretty fast and have good longevity. Budget is often a factor though and that market changes really fast. If you go pcie3 the 970 evo woth all the same caveats.
Edited by Bombastinator
5800X is good but not great, if you can get a 5800X3D, if you wanna go cheap get a 5700
Also for gaming you can save on RAM with only 16GB, and then rather get more storage, 2TB drives are faster than 1TB ones
Regarding GPU the 6800 is a better deal than a 3070, 10% faster and same price or cheaper
While it can be useful for compatibility checking,and to see what is popular, it is not 100% reliable for cheapest pricing.  Sometimes it has cheap pricing sometimes the part that is cheap was out-of-stock everywhere it looked so it is listed without a price, or the only place that has it in stock has it for a non-competitive price.  Pay attention to the pricing graph at the bottom.  Imho pcpartpicker needs a better way to differentiate “no longer being produced” the supply chain crunch has made things difficult.  Often people are out of stock because the order hasn’t yet been fulfilled but is going to be rather than hasn’t yet been fulfilled and never will be, which used to be the case often enough to count on it.
That number is fine IF ithe PSU has the most recent atx compliance.  If it doesn’t I’d bump that by 100w myself.
