Budget (including currency): $700
Country: US
Games, programs or workloads that it will be used for: Escape from Tarkov, Squad, MW2, Cyberpunk
Other details Current Build:
Intel Core i7-10700K 3.8 GHz 8-Core Processor
Asus PRIME Z490-A ATX LGA1200 Motherboard
Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
EVGA SC ULTRA GAMING GeForce GTX 1660 Ti 6 GB Video Card
Fractal Design Meshify C ATX Mid Tower Case
Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Corsair iCUE H100i RGB PRO XT 75 CFM Liquid CPU Cooler
Currently trying to upgrade my GPU to the Zotac RTX 3070 however I am also curious about other potential options.
Additionally for clarity, with my current case and cooler fan layout there is little room for larger sized GPU's that are over 290 mm.
https://linustechtips.com/topic/1481686-gpu-upgradenew-case-help/
Have you considered RX 6700XT/6750XT? They perform the same or faster than 3070 in everything except RT, and for much cheaper too.
And IDK what are you looking to get from this post, case/GPU recommendations? You didn't specify.
Occassionaly visits the forum when I have nothing to do at work.
Thanks for the reply! I have seen those as potential options as well but was worried about switching overt from Nvidia Products cuz I thought that there was some compatibility issues.
In order to clarify more, I am mostly looking for GPU recommendations and brought up the case issue to highlight that I might have trouble fitting some of the larger cards in my current setup and I do not know if it would be in my best interest to get a bigger case or not.
