UPDATED BUILD! :)
Hey Guys! As you all might have noticed, I'm pretty new here :) I was led here by Linus's vids that helped me understand the whole concept of PC Building and inspired me to build one myself! :D
I have carefully thought this through, but I have almost no knowledge of building PC's except for what I've learnt from Linus and a couple of other Youtubers out there :)
I will be building this during my Winter Holidays (November/December).
I require a bit of help with a few things:
  • I will only be overclocking the CPU when I feel it has become a little outdated and requires a bit of a boost since I've heard OCing reduces the life-span of the CPU.
  • I am also trying to have a Color theme (preferably Red and Black) as I want my PC to act as a bit of a showpiece as well ;)
  • Will the 450D fit everything?
  • Still cannot decide between Video Cards but I may end up getting an MSI or EVGA Superclocked
  • Need a way to decrease the price tag a bit without getting rid of the CPU or Graphics Card.
1. Budget & Location
My budget is USD2000 but I live in Dubai, UAE which means I would have to order everything online. (mostly Amazon).
2. Aim
This would basically be an upgrade from my laptop that is good enough for a few games like LoL, non-modded Minecraft, non-modded Skyrim, and a few basic FPS games like Counter Strike.
I would like for this to be able to run heavily modded Skyrim, modded Minecraft and maybe games like BF4 or possibly even WatchDogs if I can afford getting my hands on it :P
It would also be used for AutoCAD, bit of Photoshop, etc.
But most importantly, I want this build to be Future Proof.
3. Monitors
I will only be running one 1080p monitor that I might re-use from the Desktop I have but I am open to suggestions for a good, cheap one.
4. Peripherals
Since this is going to be a majorly Gaming PC, I would go for some Razer Kraken PRO headsets and a Microsoft Sidewinder X4 Keyboard but I still haven't decided on a Mouse.
5. Why are you upgrading?
My laptop isn't good enough to run graphic heavy games and so I would like to move to a PC as it is much more easier and better to use.
6. Build
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($309.99 @ NCIX US)
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  ($99.98 @ OutletPC)
Motherboard:  Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  ($229.99 @ Newegg)
Memory:  Corsair Vengeance 8GB (2 x 4GB) DDR3-2133 Memory  ($89.99 @ Newegg)
Storage:  Samsung 840 EVO 250GB 2.5" Solid State Drive  ($139.99 @ Amazon)
Video Card:  EVGA GeForce GTX 780 3GB Superclocked ACX Video Card  ($503.49 @ Amazon)
Case:  Corsair 450D ATX Mid Tower Case  ($120.65 @ Amazon)
Optical Drive:  Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.99 @ Newegg)
Operating System:  Microsoft Windows 8.1 (OEM) (64-bit)  ($99.99 @ Newegg)
Monitor:  Asus VG248QE 144Hz 24.0" Monitor  ($249.23 @ Amazon)
Case Fan:  Noctua NF-P12-1300 54.4 CFM 120mm  Fan  ($12.99 @ NCIX US)
Total: $2046.25
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-28 09:17 EDT-0400)
I'll be updating this with a 4790k when it comes out but for now, I'll leave the 4770k in there.
That is all I've got for now!
Thank you for reading this and for giving me your opinions! :)
https://linustechtips.com/topic/148018-my-first-build/
Go with ASUS, MSI or EVGA for your 780, you will not be disappointed. 4770K is perfectly overclockable with H100 cooling and Z87 socket, no probs there.
Is your RAM 1*8Gb or 2*4? 2*4 is more preferable (if you're not planning to upgrade to 32 Gb), and if you'll have some spare money, it's better to upgrade to 2133 MHz variant, Haswell CPUs do like higher frequencies.
Mouse - Logitech G700 is a good choice, but you'll definitely need to find a friend or go to a store so you can try the mouse in your hand before you buy it.
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/148018-my-first-build/#findComment-1976731
I have 2*4 sticks of RAM and I am not looking to upgrade it to 16GB let alone 32 GB :) Thank you for replying :)
The only concerns I have with the H100i though is that I might not be able to put the Radiator onto the top of the case without the Heat Sink of the motherboard getting in the way.
I will look into the mouse as we do have a few electronics shops here that sell peripherals but not parts for building a PC and even if they do, they're way higher than what they're supposed to be.
EDIT: as you say, ASUS, MSI and EVGA are great brands but I've also been contemplating on the Gigabyte one too. I simply can't decide on this as some have looks over performance, some having cooling and looks but very bad performance compared to other 780's, etc. Also, I will not be OCing my GPU and so I find it very hard to make this decision :/
https://linustechtips.com/topic/148018-my-first-build/#findComment-1976805
Future proofing might need a heavier series CPU mose likely intel extreme or x-series CPu or may i dare say xeon! :o mother boards and a bit of waiting, haswell reresh are coming soon! so do look on that before commiting to 4770k
Details separate people.
https://linustechtips.com/topic/148018-my-first-build/#findComment-1980764
thanks for informing me :) I do have alot of time to work out a good build and am waiting for the refresh's and possible even the 800 series if it comes out..... :o
https://linustechtips.com/topic/148018-my-first-build/#findComment-1987476
  • 3 weeks later...
Great, though I wouldn't recommend you get a case from there, since they're overpriced.
yeah they are over priced and they don't have EVGA stuff so I'll have to import a lot of the lighter components because they're charging 20% more than how much it would cost for me to import everything.
https://linustechtips.com/topic/148018-my-first-build/#findComment-2116106
