Sensor panel for new case ideas
Hi Guys.
Can anyone recommend a good sensor panel for the corsair 7000D. I was looking to mount it right on the psu shroud on the side.
I am looking to get one in a case that I can attach with magnets to the shroud and not worry about a short. Then rout the cables.
Does anyone have any types of recommendations?
Thanks.
https://linustechtips.com/topic/1477851-sensor-panel-for-new-case-ideas/
22 minutes ago, Zero83 said:
Hi Guys.
Thanks.
I use this, it's not extraordinary but it works and is relatively cheap (but small, 3.5")
https://www.amazon.com/Screen-Monitor-Computer-Temperature-Display/dp/B09TTHZYSH/ref=sr_1_14?crid=7KSLUGKS2KU&keywords=usb+monitor+panel&qid=1672520750&sprefix=usb+monitor+panel%2Caps%2C140&sr=8-14
So I was looking at this one
Ingcool 7 inch HDMI LCD 1024x600 Resolution Capacitive Touch Screen IPS Display Module Compatible with Raspberry Pi 4 3 2 1 B B+ A+, PC, Supports Windows 10/8.1/8 / 7 https://a.co/d/fgRLEta
Is there a way I can use electrical tape or a magnet to attach it to the side of the psu shroud without worrying about it shorting out?
  • 3 weeks later...
I have the same case and I use the waveshare 8.8 IPS side monitor for mine.
Amazon.com: waveshare for All Raspberry Pi/AI Computer Jetson Nano/PC Windows 11/10 / 8.1/8 / 7, 8.8" IPS Side Monitor 480x1920 No Touch HDMI Display Port Built-in HiFi Speaker, with CNC Process Alloy Enclosure : Electronics
i7-13700K | Asus ROG Maximus Z790 Hero | G.Skill Trident Z5 6800 CL34 DDR5 32GB | Corsair H170i ELITE LCD AIO | Asus ROG STRIX LC RTX 3090 Ti OC | Asus ROG Thor Platinum II 1200w 80+ Platinum | Corsair 7000D Airflow Full Tower |
