In the process of upgrading with a new mobo (ASUS prime b650m-a ax), and cpu (ryzen 5 7600x), as well as the Lian li Galahad 240. I’m trying to find out how to connect the fans to the motherboard, it comes with tons of adapters. I also have other ARGB fans that I’m wondering if they can connect to those. Any advice? Each fan has two types of connectors and the Lian li fan connectors are different than the other ones (enermax). Im very stuck with where the cables all hook up. Any help would be appreciated.
https://linustechtips.com/topic/1477419-help-with-argb-cables/
Just a heads up with ASUS boards, it's annoying that they use ARGB gen2 headers bc gen1 devices are not differentiated on the market and gen2 devices don't even exist! You can use the armory crate software to switch the headers from gen2 to gen1. The gen1 products will flash and seem broken if the header is outputting a gen2 signal. Luckily this is a set it and forget it thing. It does not require armory crate running in the background to function properly once it's set. You might have a setting in your bios, but I didn't on my z690 board. It was only in software.
https://linustechtips.com/topic/1477419-help-with-argb-cables/#findComment-15724908
