cable mangement/airflow
Solved by tkitch,
1 minute ago, phantomstrikegamer said:011 dynamic mini. i would but i didnt want to block airflow from the other card to the main gpu
Don't use 2 graphics cards. It'll do more harm than good overall, unless you have a very very specific need for two.
The top slot is the slot that is directly wired to the CPU, so the GPU *needs* to be there if you want full performance.
Also: Running a second display is a literally negligible performance hit, if it's not 3d rendering stuff. (So game on the main screeen, and have twitch on the second? You will *not* see a difference.
