casual gaming pc help
Solved by jamie.three,
21 minutes ago, nope_ said:Budget (including currency): £800-£1000
Country: UK, ENGLAND
Games, programs or workloads that it will be used for: Gaming (World of warcraft + GTA V / VI)
Other details: no peripherals required, just the desktop. No plan to go over 60hz monitor just need a casual gaming pc to handle current + new games
If all you need is 60fps (at 1080p?) then you could get something like this for even less than your budget https://uk.pcpartpicker.com/list/XdTxKp
That build should be able to hit tripple digit FPS at 1080p high settings in just about any game so it should have no problem running any new releases at above 60fps for a few years to come.
