PC Build Questions
Go to solution Solved by SleepDeprivationTheITGuy,
Going from 1080p to 1440p isn't really a reason to upgrade the CPU, it could actually decrease the load on the CPU depending on what game is being played. The 9700K definitely is getting slightly long in the tooth at this point but I think that you should throw a GPU in there before you decide whether or not to upgrade the CPU. Think about it like this; you're going to need to upgrade the GPU anyways because the 1070 Ti is not at all fit for 1440p/144fps gaming, so upgrade the GPU first. You don't need to change anything else other than maybe the power supply.
If it meets their needs this way without further change, then a CPU upgrade can wait and they'll save a little money. If it does end up being needed, then you can just order a new CPU, motherboard, and maybe cooler if the current one isn't up to a 13700K, if it is you can probably just get LGA 1700 mounting brackets for it. That's all you really need. You don't need a new case and new storage unless storage space is also an issue and upping resolution isn't all they want.
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
this is for one of my friends, there existing setup is a 9700k on a asus z390-e with a 1070ti with the ram thats in that list. He plays 1080p 144hrz but looking towards 1440p 144hrz, im wondering if its worth him upgrading from the 9700k to the i7 13700k or if he should stick with what he has and just upgrade gpu.
https://linustechtips.com/topic/1476670-pc-build-questions/
A grumpy school IT guy with too many computers.
Primary:
Intel Core i9-10900K
48GB DDR4-3600 (2x16+2x8)
RTX 3060 12GB
a lot of SATA SSDs, too many some might say
Secondary:
Intel Core i7-4790K
16GB DDR3-1600
GTX 750 Ti
HTPC:
Intel Xeon e5-1620 v2
48GB ECC DDR3-1600
GT 730 1GB GDDR5
Laptop (ThinkPad W540)
Intel Core i7-4900MQ
32GB DDR3L-1600 (4x8)
Quadro K2100M
2880x1620 IPS Display
a glass trackpad stolen from an X1 Carbon G3
I have more... these are the ones that get used fairly often though.
https://linustechtips.com/topic/1476670-pc-build-questions/#findComment-15719857
