Budget (including currency): 4k
Country: NW USA
Games, programs or workloads that it will be used for: gaming pc for long lasting support
https://newegg.io/933de82
any advice on my build would be helpful
https://linustechtips.com/topic/1476594-my-first-pc-build/
Country: NW USA
Just to let you know, i can't see your build when i click the link and based on the lack of replies im guessing other people can't either.
Using https://pcpartpicker.com/ to plan your build is about the best advice i can give, and you should be able to share links to parts lists from PC part picker with no issues
System: AMD R7 5700g (OC to 4.45GHz fixed clock) / Noctua NH-D15 / Gigabyte B550 Gaming X V2 / Gigabyte Waterforce WB RTX 2080 Ti / Crucial 4x8GB DDR4 (OC to 3800MHz Cl16) / 1TB Samsung 970 Evo Plus / Corsair 4000D airflow / Corsair TX650M / BenQ Mobius EX2510 24.5" 1080p 144Hz
https://linustechtips.com/topic/1476594-my-first-pc-build/#findComment-15720349
Country: NW USA
This is a lot.  have you ever had a gaming PC before?  Unless you specifically know that you need all this stuff, I would suggest cutting most of this out.  For about $1500 you could get something that would game about the same as this.
A lot of that stuff is not gonna be compatible either.  This config should work though costs less than half:
  • There's no point in getting a 16-core CPU for gaming.  A 10-corre is more than enough and these are faster cores that should game better.
  • A 360mm radiator will not fit in that case.  A twin tower Air cooler will though oddly enough.
PCPartPicker Part List
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($227.99 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 White 66.17 CFM CPU Cooler  ($46.36 @ Amazon)
Motherboard: Gigabyte Z690I AORUS ULTRA LITE DDR4 (rev. 1.0) Mini ITX LGA1700 Motherboard  ($140.98 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($65.97 @ Amazon)
Storage: Kingston NV2 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($109.99 @ Amazon)
Video Card: Gigabyte GV-R79XT-20GC-B Radeon RX 7900 XT 20 GB Video Card  ($909.98 @ Newegg)
Case: Thermaltake The Tower 100 Snow Mini ITX Tower Case  ($104.99 @ Amazon)
Power Supply: Corsair RM1000e 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Newegg)
Total: $1736.25
Generated by PCPartPicker 2022-12-27 09:47 EST-0500
You'll also want a gaming monitor if you don't have one.  A would say at last 1440p 160Hz if you're planning on getting an RDNA3 GPU.  I highly recommend getting an ultrawide for immersion and productivity when you aren't gaming.
Monoprice Dark Matter 34.0" 3440 x 1440 165 Hz Curved Monitor (42772) - PCPartPicker
LG 34WP60C-B 34.0" 3440 x 1440 160 Hz Curved Monitor (34WP60C-B) - PCPartPicker
Edited by SansVarnic
Merged comments
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1476594-my-first-pc-build/#findComment-15720518
