Does anyone have experience with Slackware?
I have an old PC I am try to install the 32 bit version of Slackware onto, unfortunately this PC will not boot from USB so I attempted to boot from another HDD and when I get to setup and it wants me to select the source media I naturally choose that HDD, then it ask me for a source directory and I have no idea what to put as it is not explained anywhere and nothing I try works.
EDIT #1: I just tried source from ftp/http server and it doesn't work either.
EDIT #2: Looks like I may have found my way to a fix, apparently whilst I may not be able to boot from USB I can still use it as a source drive.  Despite the fact the files written to it are exactly the same as the files on the boot HDD this apparently works, as to why I cannot go from the same HDD I have NFI... 😕
EDIT #3: Well the hist just keep on coming, I cannot startx on KDE and XFCE crashes...
https://linustechtips.com/topic/1474859-slackware-150-32bit/
Best and easiest step-by-step guide available here
It goes from downloading to complete setup.
https://linuxiac.com/install-slackware-linux/
What their asking for is what directory on the drive is Slackware located
i.e. DRIVE NAME: NAME OF DIRECTORY CONTAINING SLACKWARE
https://linustechtips.com/topic/1474859-slackware-150-32bit/#findComment-15707883
The HDD itself was called SlackwareDVD with an address of /dev/sdb1 and the directory for slackware was slackware, so I put /slackware and also just tried slackware by itself, also tried /dev/sdb1/slackware and /SlackwareDVD/slackware
I also tried other directories like isolinux and usb-and-pxe-installers to no avail.
I've look at many tutorials and most are for the 64bit version of slack which has a different installation method.
https://linustechtips.com/topic/1474859-slackware-150-32bit/#findComment-15707890
I got slackware installed, but cannot get it to work with a gui. I can login as root or a user, but startx has problems... KDE doesn't work at all and xfce works for awhile until the system locks up.
Currently I have a very low opinion of Slackware
What I really need is a video showing what to do because I am having trouble understanding a wall of text
EDIT: Well I just tried another fresh install and still cannot get startx to run properly or at all on KDE, XFCE, FLUXBOX, etc... I've just about gone through all the options
https://linustechtips.com/topic/1474859-slackware-150-32bit/#findComment-15709313
Slackware used to be a really good distro, but I don't know if it's still as good as it used to be.
However, it doesn't seem to me that you're the type of target user for Slackware. Slackware is often considered to be most suitable for advanced and technically inclined Linux users.
I think you might find more success with an operating system like NomadBSD or MidnightBSD. They have support for 32 bit systems.
OS: OpenBSD -current WM: Polybar -- bspwm -- dmenu -- picom Components: Intel 12700KF -- G.SKILL RIPJAWS @4000 CL18 -- ASUS Dual Radeon RX 9060 XT 16GB -- ASUS ROG STRIX B760-G GAMING WIFI D4 -- JONSBO Z20 black -- ARCTIC F14 -- bequiet! SYSTEM POWER 10 550W -- DeepCool AG500BK -- Kingston Renegade G5 1TB and Samsung 9100 PRO 1TB Mouse: zalman ZM-GM7 Display panel: UltraGear 34G630A-B Headphones: Kawai SH-9 Webcam: Microsoft LifeCam HD-3000 Keyboard: HP desktop 320K Microphone: Trust GXT 259 RUDOX Camera: Fujifilm X-M5
https://linustechtips.com/topic/1474859-slackware-150-32bit/#findComment-15714356
  • 7 months later...
I can start KDE with startx if I boot from DVD with (Slackware 15.0 i386):
hugesmp.s root=/dev/sda3 initrd= ro
Boot from Grub doesn't function because of kwin_x11 and ksplashqml issue.
EDIT: I have removed xf86-video-nouveau and I can now start KDE with startx if I boot from HD.
https://linustechtips.com/topic/1474859-slackware-150-32bit/#findComment-16054487
