I’m completely new to PC and this build is one I just threw together and has some changes based on some other suggestions so here’s just the updated one to see if anything else can be done to maybe make it a bit better your can be done cheaper
Budget : $US 600
Country: U.S.A
Games that it will be used for: Minecraft, Forza, Call of Duty
Other details: One other criteria is 1 tb of storage, peripherals and OS are separate from this budget and OS will be windows (idk if that will effect what parts need to be used but it’s here just in case)
https://pcpartpicker.com/list/9kQMQ6
Also of anyone knows of the psu is compatible with the case that would be helpful bc PCPartPicker isn’t 100% sure if they are
https://linustechtips.com/topic/1474095-first-pc-build/
where's the build/part list?
RELOAD BEFOR QUOTING. I EDIT MY POST ALOT!
MARK MY POST AS THE ANSWER IF I HELPED.
CPU: AMD Ryzen 5 5600 | GPU: RTX 2070 Super | Mobo: MSI X470 Gaming Pro | RAM: Corsair vengeance 32GB 8x2 3200mhz CL16 | SSD: Samsung QVO 870 1TB | PSU: SeaSonic FOCUS Plus 750 Gold 750 W 80+ Gold | Cooler: Thermaltake Contac Silent
12 | OS: Windows 11 Pro | Pcpartpicker: https://pcpartpicker.com/list/rGR6gb
Displays: ViewSonic XG2401 23.6" 1920 x 1080 144 Hz
Laptop: Lenovo Ideapad Gaming i5-1130 RTX3050 16GB | OS: Windows 11 Pro
https://linustechtips.com/topic/1474095-first-pc-build/#findComment-15702753
Mods are asleep I suppose, but this post would have been closed because you reposted the same thing within a short period of time, please continue on the previous thread.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1474095-first-pc-build/#findComment-15702757
