Will it fit??
Go to solution Solved by Dukesilver27-,
The main issue with GPU being so big, is whether it will fit the case, not the motherboard. Physically, the GPU's PCIE connector just need to plug into the motherboard, the area around the PCIE slot rarely ever affects the GPU, old boards used to have high sata port around the GPU area that would touch the GPU when connected, nowadays that is not an issue anymore.
The only thing a motherboard is of any concern to GPU choice, is whether the PCIE Gen would be an issue, and for this case, no. Any current gen CPU's motherboard would be fine with any GPU.
Why not?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1473929-will-it-fit/#findComment-15701291
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1473929-will-it-fit/#findComment-15701292
Thank You for answering. I am thinking of getting a lian li lancool 2. Any fitting issues there?
https://linustechtips.com/topic/1473929-will-it-fit/#findComment-15701295
Check the specs of the case on the product page, there should a section specifically for GPU length and width.
Then check your prefered 4090's model dimensions, make sure that the dimensions of the 4090+ 10mm for margin of error, fit in the case.
https://linustechtips.com/topic/1473929-will-it-fit/#findComment-15701310
