I have posted before and cant find an answer.
My mouse stutters intermittently (G305). Cant play competitive games or fast paced FPS. I literally build a new* PC and the issue has followed. The only parts that came forward were: Mouse, Keyboard (Razer Blackwidow), 89TB HDD, SSD & a m.2 SSD.
Resetting fixes it temporally. Its not the mouse as wired mouse does the same
PLEASE HELP. any ideas. searched online heaps already
https://linustechtips.com/topic/1473225-mouse-stuttering-issue-please-help/
42 minutes ago, SimplyChunk said:
do you use Razors garbage software?
It is installed as you literally can't have any profile on keyboard without it (it just goes demo mode when you close it). Closing the software dosent seem to fix the issue
Hi
There are several potential reasons why your mouse might be stuttering. One possibility is that there is a problem with the connection between your mouse and your computer. This could be caused by a loose or damaged cable, or by a problem with the port on your computer.
Another possibility is that there is a problem with the drivers for your mouse. Outdated or corrupted mouse drivers can sometimes cause stuttering or other problems. To fix this issue, you will need to update your mouse drivers to the latest version.
Finally, it is possible that the problem is with your computer itself. If you are experiencing stuttering in other applications or games, it may be due to a hardware or software issue on your computer. In this case, you may need to troubleshoot your computer to identify and fix the problem.
If you are unable to resolve the issue on your own, you may need to seek help from a qualified computer technician. They will be able to diagnose the problem and recommend a solution.
Hope this helped and you won’t have any problems in the future
1 hour ago, Noah Egener said:
Hi
Thanks. been through most of that (a lot to list) - 3 mice doing it on different prorts both wired and wireless (dongle). did it on old build and new build with only a few components following so not driver.
but thanks
