So I plan on getting a new laptop pretty soon as my current laptop is running Windows XP with relatively crappy specs. However, I feel that it would be better to purchase a new laptop as opposed to upgrading my current computer.
I have been looking for some laptops that have decent specs (at least i5, decent GPU, under $700 USD) yet maintain a relatively low price. So far, my best option is an Acer E1-472G-6844. It is only $600 (USD) and it contains an i5-4200U running at 1.6 GHz (kinda weak...), NVIDIA 820M, and 8 GB RAM. Is this a good choice? Why or why not?
Also, the whole list that I have been looking at can be found here: http://bloggao.blogspot.com/2014/04/decisions.html (I have been thinking of buying a refurbished Lenovo Y510p with i5, as well).
Hopefully you can help me, thanks!
PLEASE QUOTE ME WHEN YOU REPLY TO MY POSTS, thank you.
https://linustechtips.com/topic/147287-help-deciding-on-laptops/
That Nvidia GPU isn't even enough for light gaming. Especially when you consider the battery life you'll get.
Get something with integrated graphics and forget gaming or upgrade you desktop.
Intel Core i7-3770k @4.4GHz. 1.170V - Noctua NH-D14 - 8GB (2x4) G.Skill RipjawsX @1866 MHz. CL8 - Gigabyte GA-Z77X-D3H - Samsung 840 250GB - XFX HD7970 DD GHz. @1125MHz - CM 690 II - Seagate Barracuda 2TB + WD RED 3TB - Corsair RM750X
 FiiO E10 - Sennheiser HD 598 - Edifier R1600T - Sony MHC-EX50 - Razer Blackwidow Ulitmate 2013 - Razer Deathadder 2013 - LG IPS237L - Dell P2314H - Philips 237EQPH - LG 47LB561V
 LG G2 - HP Spectre X360 - Audio Technica ATH-M50X - Sennheiser IE 60
https://linustechtips.com/topic/147287-help-deciding-on-laptops/#findComment-1967667
