Budget : 1200€-1500€
Country: Europe (Slovenija)
Games, programs or workloads that it will be used for: State of decay 2, Company of heroes 3, Cyberpunk 2077, Anno 1800, Civilization 6, Witcher 3, Mount and blade bannerlord, Minecraft, Fusion 360 ...
Other details: I am doing a completely new build for my new pc, i did some part picking myself but i have no experience as my previous PC was a pre built. So i need someone to check my build and any corrections and feedback are welcome.
Ps. I am looking for price to performance so if there is a better alternative with AMD sistem i wont mind switching to AMD
This is what I got together.
i5-12400F
MSI PRO B660M-A DDR4
GPU: didn't pick one open for suggestion
1TB Samsung SSD 980 M.2 PCIe 3.0 x4 3D-NAND TLC
650W Pure Power 11 FM Modular 80+ Gold
Phanteks Eclipse P400A
16GB G.Skill RipJaws V DDR4-3600
https://linustechtips.com/topic/1471689-my-first-pc-build/
If there are 1Tb NVMe drives less expensive than the Samsung 980, consider getting one of them. Unlikely to be any noticeable performance difference.
DDR4-3200 CL16 is usually less expensive and a better match for the i5-12400F.
You might want to consider a 5600X build, slightly better cpu performance likely less expensive system. But given the budget an i5-13600KF may also be possible.
Optimal GPU depends on you monitor resolution and refresh.
https://linustechtips.com/topic/1471689-my-first-pc-build/#findComment-15685375
