2 minutes ago, Cuacko said:
So, audio from motherboard to headphones is ok, but the NVIDIA High Definition Audio that is supposed to be my monitor does not work. No sound comes out of my monitor. I dont have my headphones with me and I need audio. Please help
What monitor do you have?
17 minutes ago, Cuacko said:
It does
I just went to the first product page, which says it doesn't. The volume buttons are usually for controlling the 3.5mm jack that it has on the back.
-> https://www.caseking.de/samsung-odyssey-g3-f24g3-61-cm-24-zoll-freesync-va-dp-hdmi-tfss-137.html
It's in German though.
I can also not find any mentions about speakers on them.
