Budget (including currency):  around $3500 au
Country:  Australia
Games, programs or workloads that it will be used for: Mostly games and a bit of AutoCAD for designing
Hello I need some help with building my gaming pc, since I want to make sure that its somewhat balanced and the parts are compatibly with each other. I know that this build is slightly overkill but I just wanted a pc will last me a long time, can handle anything i throw at it, like demanding games like cyberpunk 2077 and I don't plan to do any over clocking. I am mainly using this for Gaming at 1440p for now but I plan to get a 4k monitor next year.
Here is the specs:
$569 CPU AU, : Amd Ryzen 7 5800x3D
https://www.ple.com.au/Products/651832/amd-ryzen-7-5800x3d-8-core-16-thread-up-to-45ghz-am4-no-hsf-retail-box
$179 AU, Case: Lian Li Lancool 2 Mesh RGB
https://www.ple.com.au/Products/648881/lian-li-lancool-ii-mesh-rgb-tempered-glass-usb-c-mid-tower-case-black
$174 AU, Ram: Corsair 32GB Kit (2x16GB) DDR4 Vengeance RGB Pro SL C18 3600MHz - Black
https://www.ple.com.au/Products/644747/corsair-32gb-kit-2x16gb-ddr4-vengeance-rgb-pro-sl-c18-3600mhz-black
$299 AU, Storage: Samsung 970 EVO Plus 2TB M.2 NVMe SSD
https://www.ple.com.au/Products/634647/samsung-970-evo-plus-2tb-m2-nvme-ssd
$119 AU, ID-COOLING AuraFlow X 240 EVO 240mm AIO CPU Cooler - Black
https://www.ple.com.au/Products/654466/id-cooling-auraflow-x-240-evo-240mm-aio-cpu-cooler-black
$239 AU, Power Supply: Corsair RMe Series RM1000e Fully Modular Low-Noise ATX Power Supply
https://www.ple.com.au/Products/653131/corsair-rme-series-rm1000e-fully-modular-low-noise-atx-power-supply
GPU: I am planning on getting the AMD RADEON RX 7900 XTX when it gets lunched since Nivida 40 series is like an extension of the 30 series.
Mother Board: Gigabyte B550 Aorus Elite AX V2 AM4 ATX Desktop Motherboard Rev 1.1
https://www.ple.com.au/Products/646068/gigabyte-b550-aorus-elite-ax-v2-am4-atx-desktop-motherboard-rev-11
$659 AU Monitor: Gigabyte M32Q 31.5" QHD Adaptive Sync 170HZ IPS Gaming Monitor
https://www.ple.com.au/Products/646156/gigabyte-m32q-315-qhd-adaptive-sync-170hz-08ms-ips-gaming-monitor
I have already bought the Ryzen 7 5800x3D since i managed to buy one on special and got $180 off. i plan to get the parts around black Friday and then finish the build off with the 7900XTX around December the 13th, Is there any parts should I change or add? Also what windows system should I use, i have heard that windows 10 is better then windows 11. If someone could please help me that would be great, since this is the first time I am building a pc.
https://linustechtips.com/topic/1469260-need-help-building-a-slightly-overkill-pc/
