What one of these two AIO's would be best for a i9-13900k? LIAN LI GALAHAD AIO 360 RGB UNI FAN SL120 EDITION BLACK , Dual 120mm Addressable RGB Fans AIO CPU Liquid Cooler or a corsair icue h150i elite lcd. Lastly what would be a good psu for the i9-13900k and tuff gaming 3090ti? I want to overclock everything and not sure what would be a good wattage. I know the recommend system wattage for the 3090ti is 1,000 watts but see a lot of people recommend either a 1,200 or 1,500 watt. I'm not worried about the price, just want something decent and reiable.
https://linustechtips.com/topic/1468432-advice/
Both those AIO's are trash. For PSU I would recommend the Corsair RM1000x. You don't need 1200 or 1500w
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1468432-advice/#findComment-15661856
5 minutes ago, alan93 said:
any suggestions?
EKWB AIO, Arctic Liquid Freezer AIO, Or deepcool ls720 aio
https://linustechtips.com/topic/1468432-advice/#findComment-15661894
