Budget (including currency): 12 000 SEK
Country: Sweden
Games, programs or workloads that it will be used for: Elden ring, dark souls, OW2, watching series etc
I am building my first ever pc build and want help with how my build should look. I have decided on the Gpu and Cpu to be 3060 ti and Ryzen 5 5600x, following those components how should the rest of the build look, fitting the budget to get the most worth and performance. The gpu and cpu will take up about 7000 - 7500 SEK of the budget. I have decided to use the stock cooler that comes with the cpu for the moment to save some money (and to upgrade later) and am thinking of using the 4000D airflow as case.
I would really appreciate it if you would help me with e.g what motherboard to pick, pcpartpicker build is very appreciated 🙇
Thank youuu :)))
https://linustechtips.com/topic/1466594-help-with-first-build/
Country: Sweden
Thank youuu :)))
Just a heads up, the r5 5600 is basically the same CPU as the 5600x but is cheaper. Also, the 6700xt is a better GPU choice than the 3060ti for raw performance.
Here’s a good list for you with the parts you chose https://se.pcpartpicker.com/list/n9jQNc
It’s a tiny bit over budget, but not very much, and it’s gonna save money in the long run by not having a garbage motherboard that you’ll need to replace if upgrading to a better CPU- this mobo can even handle a 5800x3D or 5950X
https://linustechtips.com/topic/1466594-help-with-first-build/#findComment-15647668
