22 minutes ago, yo i like pugs said:
So i am not useing the cpu pin on my Lepa N500-SA 500W 20+4-Pin ATX Power Supply so like can i use it for pci power since i am not using it
as is ? nope.
Different pinout
Refresh before you reply
https://linustechtips.com/topic/1466526-i-need-help/#findComment-15647154
If its a 8-pin CPU power cable you can use an adapter like this one.
https://www.amazon.com/Female-Adapter-Splitter-Graphics-COMeap/dp/B07CZCFFST
but I recommend only using one of the PCIe ends, not both
If you want me to answer, please use the quote function or tag me. I dont get notified unless you do
https://linustechtips.com/topic/1466526-i-need-help/#findComment-15647175
