hp spectre display issues
Solved by another_user,
That did not work in my case.
What I did now: I manually deinstalled every intel app that was on the machine (related to graphics) and downloaded the general "intel graphics driver" (it was basicly the only availible intel graphics driver/app for windows 11) and installed it.
For now, it is working just fine and the flickering is gone.
Since the updates before did not work, I'd suggest, that there was something about the fact that intel rebranded the graphics software at some point, which ended up with more than one running on the machine. Also, it don't know, why there was more than one, since I didn't installed any kind of graphics driver manually before.
