Looking for help with a build
Go to solution Solved by ZetZet,
PCPartPicker Part List: https://de.pcpartpicker.com/list/7QtF3y
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  (€247.99 @ Mindfactory)
CPU Cooler: Deepcool AK400 66.47 CFM CPU Cooler  (€35.90 @ Alza)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  (€152.58 @ notebooksbilliger.de)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  (€99.90 @ Amazon Deutschland)
Storage: Crucial P2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€76.90 @ Alza)
Video Card: Asus TUF-RX6800XT-O16G-GAMING Radeon RX 6800 XT 16 GB Video Card  (€649.00 @ notebooksbilliger.de)
Case: Phanteks Eclipse P400A ATX Mid Tower Case  (€87.89 @ Caseking)
Power Supply: ADATA XPG CORE Reactor 850 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€109.94 @ Computeruniverse)
Total: €1460.10
Generated by PCPartPicker 2022-10-20 19:18 CEST+0200
Something like this maybe. All value components for maximum FPS in games.
You could swap to Ryzen 5 5600 and 6900XT for more FPS, but less CPU power.
Budget (including currency): 1000 - 1500 €
Country: Germany
Games, programs or workloads that it will be used for: Python Programming (Apps and game development) and Gaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): got 2  24 Zoll Monitor  1920x1080p /144 Hz / 2 ms
peripherals are not needed got an Headset, mouse and keyboard. Looking to buy the PC end of year and starting from zero since i used notebooks so far. I'm looking for an update since my 7 year old notebook can't handle anything anymore.
Not sure if its possible to use it or not but i got an Samsung 870 QVO 1TB SATA 2,5 Zoll SSD in my Notebook wich i could use
thanks for help in advance
Karka
https://linustechtips.com/topic/1462271-looking-for-help-with-a-build/
I don`t have the time right now, to recommend you a system. But when you buy one, consider mindfactory.de as your main source. They usually are the cheapest and have good service. And no, i have no affiliation to them besides being a customer.
Viel Spaß beim zusammen bauen!
Total: €1460.10
