Power supply cable compatability?
Solved by Spotty,
16 minutes ago, TheSpicyWarrior said:How can I figure out if my power supply is a type 3 or 4?
And if it is indeed compatible is there specific ports on the psu where I should be plugging the cable in?
The HXi uses Type 3 cables. The only difference between Type 3 and Type 4 is the motherboard 24pin cable, the PCIe cables are interchangeable.
Corsair has a chart on their website which lists cable compatibility between power supplies. It will tell you if it is a type 3/4 cables. Almost all of their power supplies use either type 3 or type 4 cables.
https://www.corsair.com/ww/en/psu-cable-compatibility
You can use Corsair's 12VHPWR cable with your HX1000i. It plugs in to any of the available 8pin connectors on the PSU.
