I went on my computer today and noticed a red cross over the sound icon ,and my speakers won't work (no they're not muted). When i go to my audio devices the speakers don't show up, and my drivers say they are up to date. I tested my speakers and they work. I am using the on-board audio on the gigabyte g1 sniper m5
https://linustechtips.com/topic/146051-help/
True your front ports and make sure the drivers are there... did you update windows?
The time you enjoy wasting, is not wasted time.
https://linustechtips.com/topic/146051-help/#findComment-1950207
A prompt to update to 8.1 came up and i clicked it but it said i couldn't update
and i tried front ports, and nothing worked
I used to have the same problem... give me a second I try to figure out what I did to fix it..
https://linustechtips.com/topic/146051-help/#findComment-1950255
