Memory Diagnostic Tool reporting Memory Hardware Issue
Hi
Hope someone can help
I recieved a BSOD error
According to the dump files, possible cause
ntoskrnl.exe (nt+0x3F8FA0)
win32kfull.sys (win32kfull+0x58752)
In response I ran SFC /Scannow and The Memory Diagnostic Tool
Results of which was
SFC /Scannow - Found and repaired corrupted files
The Memory Diagnostic Tool - Reported fault with memory and to contact manufacturer (Corsair)
I've attached the resules of the tests
I'm hoping someone can shed more light on the results
My PC Spec
VENGEANCE® LPX 64GB (4 x 32GB) DDR4 (CMK64GX4M2D3600C18)
Ryzen 5 5900x
Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler
Gigabyte Aorus RTX 2080TI 11G
ROG Crosshair VIII Dark Hero
Corsair HX Series™ HX1200i — 1200 Watt 80 PLUS® Platinum Certified Fully Modular PSU
Dump Files report.txt Memory Diagnotic Results - 1.txt Memory Diagnotic Results - 2.txt
I had a similar issue with Corsair vengeance LPX 3600C18 2x16GB on my 5900x, it worked for 3 months then got a bsod and one stick just didn't work anymore, wasn't even seen by BIOS...
RMAed it (or rather Amazon allowed me to get a replacement for free...) and weirdly in the new pack one also refused to work!
So I took both working sticks, sent back the rest, no issues since, even after tightening CAS to 16 instead of 18
I've reduced the CAS Latency from 18 to 16 and the system seems to behaving a lot more smother, hopefully this fixes the issue, but I'll run a ram test to make sure.
Changing the CAS Latency to 16 seems to have, at least from the looks of it, done the trick
ReRan the Memory Test Tool and it came back no issues. and the system from the feel of it, has improved in its responsiveness
