Hey Guys,
I'm new to the forums and I have a problem. It started when my hard drive began to dramatically slow down to a crawl and would refuse to play videos or load games onto it. I checked via task manager and it seems to be at 100% disk usage with 0 read/write everytime I tried to load a video, with an occasional 300 kb/s. I knew I had to make a backup from my drive before it completely fails. I checked Aoemi to realize it has a lot of bad sectors. I have my new drive on me to take a disk image for it since attempting to clone from my old drive would take forever to do so. The disk image failed with various error codes like error 433 and 0. I tried different softwares for disk imaging (Macrium, Aoemi, EaseUs, etc.) and nothing seems to be working. I also did the command prompt as an admin with chkdsk /f /r and was stuck and did not see any progress. I did check the S.M.A.R.T. test with CrystalDiskInfo on it and it says its unknown. I also tried removing Superfetch and Windows Search and still nothing. Even removing startup programs doesn't seem to work.
Also you might be wondering, yes my current SSD is my main drive with my OS on there and only used the old drive to store games and videos. I had that drive working fine for 8 years with no issues until recently. I've looked desperately for the past few weeks to see what is causing all this. I guess it must be my old drive is getting too old by now and needs to be replaced. At first, I thought a Windows update is causing this issue. That is until I checked via Aoemi and with the bad sectors. I need help with this since I've never experienced an issue like this. I've exhausted all my options at this point.
My hard drive in question is a Seagate (ST1000DM003-1CH162). I had it since 2014. Any help is greatly appreciated. Thank you!
https://linustechtips.com/topic/1455712-hard-drive-backup-problem/
Well, it's dying and there's not much you can do about it. If you really care about what's on it, then send it off for data recovery but that can cost several hundred USD.
The chassis that drive is in is not one of the best out there, and that drive seems to have just reached the end of its life.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
