I want to replace my stock fans in my 600T corsair case, purely because I find these stock fans loud and don't feel like I can trust them cooling wise.
I was planning to buy the corsair AF/SP Series fans, but I have no idea where to place which ones.
I want to replace the frontfan by 2 fans at the front, 1 fan on top by 2 on top, and replace the back intake fan.
Any help on which ones to place where?
And how much improvement will I be able to see over the stock fans?
Thanks in advance :)
CPU: Intel® Core™ i7-2600K @ 4,8 GHz.
GPU: MSI Twin Frozr IV Advanced GTX780.
Storage: 3x 1TB WD, 1x 240GB OCZ Vertex 3 SSD.
Memory: 4x4GB(16GB) Corsair Dominator 1600 MHz 9-9-9-24 2T.
Case: Corsair 600D.
PSU: Corsair 850ATX.
Soundcard: Creative fatal1ty championship series.
Motherboard: ASRock fatal1ty P67 Professional.
Monitors: BenQ XL2410T (TN Panel) - 120Hz - Gaming/primary monitor, LG 24MP76 (IPS Panel) - 60Hz - Quality/entertainmaint/secondary monitor.
Keyboard: Razer BlackWidow Ultimate 2013.
Mouse: Logitech G500. (no weights, 1600 DPI, windows 6/11, no accel, markC applied.)
Mousepad: Steelseries QcK+ Fnatic Edition.
Headset: SteelSeries 7H Fnatic Edition.
https://linustechtips.com/topic/1454-replacing-my-case-fans/
IF you really want case fan. Use those NZXT FZ series fan. or the Bitfenix spectre.( LED or non- LED is up to you to decide)
Corsair AF and SP are okay but really out-standing fan case.
Any fans below 10 dolars would be consider trash i think since it doesn't do any good for your computer.
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20182
Still haven't got a clue which ones to use where.
I am not planning on changing my mind over the Corsair fans since I got a corsair case. Lol.
Case: Corsair 600D.
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20309
AF is for Heatsinks' date=' etc... and SP is for ventilation like intake, etc... AF = Force (and maybe pressure) SP = Pressure I hope this clears it up ^^[/quote']
Thought it was reverse.
SP for heatsinks and AF for case intakes?
Case: Corsair 600D.
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20373
AF -> Air Flow
SP -> Static Pressure
At least that's my understanding.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20404
AF -> Air Flow SP -> Static Pressure At least that's my understanding.
True that, but which one to place where?
Replace all my stock intake fans with AF or SP?
Case: Corsair 600D.
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20514
AF is for Heatsinks, etc... and SP is for ventilation like intake, etc...
SP = Pressure
You are right indeed, stupid of me for not checking corsairs site...
From Corsair site: "AF models performs best in unrestricted spaces with at least 3cm of clearance"
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20565
True that' date=' but which one to place where? Replace all my stock intake fans with AF or SP? [/quote']
Put the AF fans on the case a general airflow and SP fans on your radiator/heatsinks. Done
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20582
True that' date=' but which one to place where? Replace all my stock intake fans with AF or SP? [/quote'] Put the AF fans on the case a general airflow and SP fans on your radiator/heatsinks. Done
Thank you very much, I knew I was right but I just needed some securance.
Thanks! :)
Case: Corsair 600D.
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20728
Thank you very much, I knew I was right but I just needed some securance. Thanks! :)
No Problem! This is what the forums are for. I hope linus sees this!
https://linustechtips.com/topic/1454-replacing-my-case-fans/#findComment-20750
