Help with a new build
Go to solution Solved by brob,
Everything should fit comfortably in the case.
Budget (including currency): 8500 PLN (~1800USD)
Country: Poland
Games, programs or workloads that it will be used for: Gaming and programming. Games: Apex Legends, AC Valhalla, Elden Ring, Valheim, Elder Scrolls Online | Programming: some Dockers
Here's what I was thinking about:
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor
Cooling: SilentiumPC Fortis 5 140mm
Motherboard: Gigabyte B660 GAMING X AX DDR4 ATX LGA1700 Motherboard
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Storage: Western Digital Black SN750 1 TB M.2-2280 NVME Solid State Drive
Video Card: Gigabyte GeForce RTX 3070 Ti 8 GB GAMING OC Video Card
Power Supply: SilentiumPC Supremo FM2 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit
Monitor: Samsung Odyssey F24G35TFWUX (acting as a secondary, I already have a main monitor)
Case: Lian Li Lancool 215 ARGB
The thing is, I'm pretty much streching my budget here, so I'm looking for some cost cuts without major perfromance drops. I'm also wondering whether the case and cooling I've picked will be sufficient. Any tips will be appreciated!
https://linustechtips.com/topic/1452917-help-with-a-new-build/
18 hours ago, brob said:
Did you consider the i5-12400(F)? Offers same performance in most games.
Yeah, but the price isn't that different in the shop I'll be buying from. What about the case? Do you know whether everything will fit in there? I'm also wondering if the cooling I've picked will be enough?
https://linustechtips.com/topic/1452917-help-with-a-new-build/#findComment-15550145
You don't actually name the cooling. 🙂
From or gaming and general use, the stock cooler would be fine.
https://linustechtips.com/topic/1452917-help-with-a-new-build/#findComment-15550236
