Posted August 27, 2022 Budget (including currency): 1100USD Country: USA Games, programs or workloads that it will be used for: Modded Skyrim, Halo MCC, and perhaps some streaming in the future. The streaming is optional though Other details: TLDR: Any advice on Parts and why I should go for that part. I already have a MSI B450 Gaming Pro Carbon AC, I bought it a couple years ago and its just been sitting in the box, so I finally decided to try my hand at building a pc. I want to use the motherboard as the base, since I already have it and it will allow more money to be spent on the CPU and GPU. I know what I need just not what exact model and why. i.e. I know what the CPU does, I just don't the difference between the individual CPU's. I plan on getting them in bulk when possible. I put together a rough build in PC Part Picker, I am just looking for any advice possible. I rather not just get told what to get but also why I should get that exact model and how it compares to other ones. Link to comment https://linustechtips.com/topic/1451956-first-build-adivce/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 27, 2022 (edited) Some of this list doesn't make any sense. $140 for a 400 watt power supply? Even if it's a good model. That SSD is way too expensive for a gaming focused PC. That price for a last gen GPU is surprisingly good, though. Consider this: PCPartPicker Part List: https://pcpartpicker.com/list/Qfh3sL CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor ($177.99 @ Amazon) Motherboard: MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard (Purchased For $0.00) Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($47.97 @ Newegg) Storage: Crucial P2 500 GB M.2-2280 NVME Solid State Drive ($39.99 @ Amazon) Video Card: MSI GeForce RTX 3060 12 GB GAMING X Video Card ($379.99 @ Amazon) Case: BitFenix Nova Mesh SE ATX Mid Tower Case ($79.90 @ Newegg Sellers) Power Supply: Antec NeoECO Gold ZEN 500 W 80+ Gold Certified ATX Power Supply ($58.95 @ Amazon) Total: $784.79 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2022-08-27 19:43 EDT-0400 Beefed up the graphics card and power supply. Grabbed a case that has better ventilation, added a more suitable SSD. I went with the 5600 instead of the 5600X because the performance is identical in modern games. 22 minutes ago, FlamingSpartan23 said: I know what the CPU does, I just don't the difference between the individual CPU's With Ryzen CPUs which is what you're comparing, the generation is a big factor. Their current 5000 series CPUs are the newest and of course require firmware to match. You said the motherboard has been sitting in a box for a while, so it will certainly need an update. Lucky for you, it has a BIOS flash button so you can flash without a compatible CPU. Make sure to check the manual/youtube for how to properly do this, and check their webpage for the appropriate BIOS version. If you want, saving money with a used processor could be good. Does the box of the motherboard indicate what generation it's compatible with? You might have "Ryzen 3000 series ready" on it, which would result in a flash-free experience and you can go for a used Ryzen 5 3600 off eBay. Edited August 27, 2022 by Fasauceome I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 11 and Fedora Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. PSU tier list How many watts do I need? PSU misconceptions, protections explained, group reg is bad Link to comment https://linustechtips.com/topic/1451956-first-build-adivce/#findComment-15541927 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 27, 2022 OK, so there are a lot of weird choices in this system (do not buy that PSU, for instance, it's a $40 PSU at best, not a $140 PSU). I'm gonna preface all this by saying that it's probably a good idea to wait a few weeks before building the CPU and by extension the rest of the parts, AMD is announcing next gen gear on Monday so you might be able to get a deal on last gen parts when they inevitably go on clearance (it's a new socket so you won't be able to use them in your current board). It's probably a good idea to go 5600 instead of the 5600X, they're basically the same CPU but one is $20 cheaper, might as well save $20. The SSD is a pretty weird choice. If you really want a SATA drive, the MX500 is cheaper and a better drive, and there are NVMe drives like the SN570 that are still cheaper and much faster. Besides, 500GB is not really enough for a gaming system nowadays, I'd really recommend you upgrade to a 1TB drive, it's not much more and a lot more usable. 2060s don't make a ton of sense unless you really need CUDA support. AMD GPUs are currently a much better bang for the buck, and the 6600 is currently cheaper and faster, and the 6600 XT (a worthwhile upgrade over the 6600) is only $50 more You don't need a high end PSU, but at the same time a 400W PSU for $140 is a ripoff. The EVGA G5 650W is less than half the price for a better PSU. You can get a Windows key for $20 from a key reseller. Get one of those instead. https://pcpartpicker.com/list/RVGP78 Link to comment https://linustechtips.com/topic/1451956-first-build-adivce/#findComment-15541934 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 28, 2022 I would say, unless you want to stay SATA on the storage, maybe go M.2. You can find 1TB m.2's for in that $100 USD price range. But you can find some SATA 3 drives from Samsung that are twice the capacity around the $100 price range as well. As for that PSU, would switch that one out for something else. You can get higher wattage that are semi-modular with 80+ Gold rating for cheaper. Link to comment https://linustechtips.com/topic/1451956-first-build-adivce/#findComment-15541951 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
