Posted August 11, 2022 So, I used to be able to use my XBOX One controller via bluetooth, no wireless dongle or extra stuff. Then all of the sudden, it would not work, and apparently not working is the default, and I was apparently lucky for having it work before. So I went wired. Switched over to Series X when it came out, same thing, no bluetooth. Been playing on it wired, which is not nearly as bad because USB-C is actually secure unlike Micro USB. However, recently my specific controller doesn't connect. Right now, it is connected via USB to the PC, but the XBOX turned on. It's literally wirelessly connected to the XBOX, while physically plugged into the PC. Usually some power off/on cycles work. This has been happening more often recetnly, and power cycling works less often. Like I'll have to not use it for like a week, and then it somehow works...? Until it doesn't. It's really only my main use Series X controller. PS5 controller works, but some games, like Gamepass stuff requires DS4Windows and I prefer XBOX stick placement in all games that aren't fighting games. My other XBOX pads work, but they are special edition wall hangers. Any help, other than buy a new 'main use' XBOX controller, which I feel is wasteful..? AMD Ryzen 7 7700X- Asus ROG Strix X670E-A DDR5 5600 32GB CL32 -Asus Strix Nvidia RTX 4090 -Lian Li Lancool 3 4.5TB storage; 3xM.2 NVME, 1xHDD. MSI A1000G -Acer CB282K- Corsair H150i, Corsair fan exh, x3 Lian Li intake fans, x3 Lian Li lower fans Corsair K57- Redragon Vampire Elite Lenovo AMD A6/R4 Laptop XBOX Series X, PS5, Switch, Dreamcast Fun cars - Evo X built cammed 6266, Mustang S550 NA Cammed Cobrajet Link to comment https://linustechtips.com/topic/1448837-xbox-controller-woes/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2022 I haven't been able to get the wired connection to work on my desktop. The way you switch them is you hold the share button on the top of the controller (by the left triggers) and the xbox button. Once it starts rapidly flashing you can connect it to PC via bluetooth. My PC Specs: (expand to view) Main Gaming Machine CPU: Intel Core i7-14700K CPU Cooler: Deepcool LT720 Motherboard: MSI PRO Z790-P WIFI Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400 Storage 1: Samsung 990 Pro 2 TB Storage 2: Crucial P3 Plus 4 TB Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB Power Supply: Corsair RM850 850W Case: Corsair 7000D Airflow Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7) Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz Link to comment https://linustechtips.com/topic/1448837-xbox-controller-woes/#findComment-15520007 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2022 Author 2 hours ago, TylerD321 said: I haven't been able to get the wired connection to work on my desktop. The way you switch them is you hold the share button on the top of the controller (by the left triggers) and the xbox button. Once it starts rapidly flashing you can connect it to PC via bluetooth. that doesnt work, hasb't worked for a long time, and apparent;y everyone thinks its normal that xbox controllers dont work via BT, and always suggest buying a dongle... AMD Ryzen 7 7700X- Asus ROG Strix X670E-A DDR5 5600 32GB CL32 -Asus Strix Nvidia RTX 4090 -Lian Li Lancool 3 4.5TB storage; 3xM.2 NVME, 1xHDD. MSI A1000G -Acer CB282K- Corsair H150i, Corsair fan exh, x3 Lian Li intake fans, x3 Lian Li lower fans Corsair K57- Redragon Vampire Elite Lenovo AMD A6/R4 Laptop XBOX Series X, PS5, Switch, Dreamcast Fun cars - Evo X built cammed 6266, Mustang S550 NA Cammed Cobrajet Link to comment https://linustechtips.com/topic/1448837-xbox-controller-woes/#findComment-15520209 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2022 3 minutes ago, diegoaccord said: that doesnt work, hasb't worked for a long time, and apparent;y everyone thinks its normal that xbox controllers dont work via BT, and always suggest buying a dongle... Oh I completely forgot! Not all XBOX controllers work via Bluetooth but it is very easy to tell if yours will/should. View the attached image. Image found in "Connect a Controller to a Windows 10/11 device > Option 3: Bluetooth" Connect an Xbox Wireless Controller to a Windows device | Xbox Support My PC Specs: (expand to view) Main Gaming Machine CPU: Intel Core i7-14700K CPU Cooler: Deepcool LT720 Motherboard: MSI PRO Z790-P WIFI Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400 Storage 1: Samsung 990 Pro 2 TB Storage 2: Crucial P3 Plus 4 TB Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB Power Supply: Corsair RM850 850W Case: Corsair 7000D Airflow Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7) Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz Link to comment https://linustechtips.com/topic/1448837-xbox-controller-woes/#findComment-15520222 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 12, 2022 They work via Bluetooth (if you have the model which has BT capability) but the dongle is better. Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy. If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear. Link to comment https://linustechtips.com/topic/1448837-xbox-controller-woes/#findComment-15521450 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 13, 2022 On 8/11/2022 at 3:48 PM, TylerD321 said: Oh I completely forgot! Not all XBOX controllers work via Bluetooth but it is very easy to tell if yours will/should. View the attached image. Image found in "Connect a Controller to a Windows 10/11 device > Option 3: Bluetooth" Connect an Xbox Wireless Controller to a Windows device | Xbox Support Yeah my specific model number doesn't support Bluetooth on PC. I think I googled it years ago. I just got the Xbox adapter so now every Xbox one controller will work on my PC wirelessly. Link to comment https://linustechtips.com/topic/1448837-xbox-controller-woes/#findComment-15522674 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
