Low ram mhz
By
El Pipa
in Troubleshooting
in Troubleshooting
Solved by El Pipa,
10 minutes ago, 8tg said:That is correct, DDR stands for double data rate, it will read ram at its original speed and it’s doubled.
IE 1600mhz ddr3 is 800mhz
3200mhz ddr4 is 1600mhz
Ive just told him how to update bios beacause he had one from 2018 xd. Now its takes the ram speeds at 2666
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
