so this started a few weeks ago
i was playing battlefield 5 as usual and then suddenly the screen went gone for 5 second and then when it came back
the screen was orange and audio was messed up too
no BS or anything
it just happened and i had to hard shutdown the system to get it to boot again
but i thought maybe 1 in 1000 time crashing was normal and then it started happing in pretty much every single session of my game
sometimes after 2 minutes into the game and sometimes its fine for hours
i play BF5 Warzone Fall guys the OG C&C Generals (yes i still play it after 20 years) and Control and this behavior only happens on BF5 and fall guys
Control and warzone and generals are fine and i never had any issue with them
i was on win 11 and i thought maybe that's what messing with me but i switched to windows 10 last night and no such luck
i already tried
bios reset and update
DDU with the latest driver
latest windows updates
new windows 10 install
i did prime95 torture setting and hours of furmark and a gpu vram tester at the same time and they passed it all the way with no issue
i also did memtest86 for added bonus
nothing was bad hardware wise as far as i can tell and all the temps are in 60-70 range with cpu and gpu boosting to the clock speed that they should
but after checking event viewer i noticed that every time i get this error i get a crash
The description for Event ID 56 from source Application Popup cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
ACPI
2
The message resource is present but the message was not found in the message table
specs:
i3 10100
Gigabyte H410m S2H rev 1.0
Zotac GTX 970 AMP EXTREME CORE EDITION
16 GB Kingston Hyperx Fury 2400 mhz cl 15
intel stock cooler
Adata XPG GAMMIX S5 256 GB NVMe drive (BF5 is on this drive)
an old 2.5 inch 640 GB Toshiba sata hard drive that i took out of an old laptop (which has fall guys and the rest of the games)
480 watt 80 plus bronze power supply from a local brand that i actually trust
what's going on here?
https://linustechtips.com/topic/1442527-system-keep-crashing/
I would bet on PSU, gtx 970 recommended 500 Watt PSU. Is my wild guess.
I red more into your problem someone on reddit suggested
" disabling C-States and enabling Power Loading"
it helped a few people
Gigabyte X570 Aorus Elite,  Ryzen 9 3900x, Dark Rock Pro 4, 16 GB Crucial Ballistix  RGB 3600 MHz CL16 RAM, RTX 3080 TI FE Watercooled, 6 Case Fans,  Fractal Design Meshify S2
You are awesome, stay safe and healthy.
https://linustechtips.com/topic/1442527-system-keep-crashing/#findComment-15476186
psu is fine
me and my friend tested it with a load generator and also it passed al the test at the same time
i would try the c state and power thing
https://linustechtips.com/topic/1442527-system-keep-crashing/#findComment-15476190
hi
quick update
it didn't work but i discovered something else
I'm getting thousand of these warning in event viewer
A corrected hardware error has occurred.
Component: PCI Express Root Port
Error Source: Advanced Error Reporting (PCI Express)
Primary Bus:Device:Function: 0x0:0x1D:0x2
Secondary Bus:Device:Function: 0x0:0x0:0x0
Primary Device Name:PCI\VEN_8086&DEV_A39A&SUBSYS_50011458&REV_F0
Secondary Device Name:
i found out what pci express is making all this noise
the problem is i dont really know what its related to
i have a gpu at gen3 16x and an NVMe drive at gen3 2x
here are photos
https://linustechtips.com/topic/1442527-system-keep-crashing/#findComment-15478018
