does the x570 a pro have a temperature header
Solved by Valkyrie Lenneth,
17 minutes ago, schmxtr said:probably sounds dumb but can i just plug it in any fan header slot or do you mean something like the corsair commander pro and sry if im stoopid
i mean a front panel fan controller, example
most of them have temperature sensor connectors on it ( and include temp probes ) u can just plug ur water temp probe/watertemp reader onto that
make sure to get one with temperature sensors that way u can just connect the watertemp sensor onto it
