Please help identify this electronic component
Solved by RONOTHAN##,
That's a capacitor in the audio section. It's not necessary, it's just that you might have slightly worse audio on that board. If you've got soldering skills, you can add another cap on there (it's an MLCC, find the right size package and just get a larger package for this), but personally I wouldn't care enough to worry about that.
